Water in front passengers side footwell
Hi got water leaking into passengers side footwell. It seems to be leaking in on the left hand side. If I take of the trim cover on the side of the dash and put my hand in along where the door hinges bolt through all that side is wet and seems to be wet upwards.
I've gad the window removed and resealed but still leaking.
I pour water over screen and it seems to run out onto floor with nothing building up in scuttle.
Any ideas? It does not have a sunroof. Could it be water from roof rails leaking down?
there is someone on here who had leaking roof rails.  it sounds more like its leaking from the bulkhead though, did you check the cabin filter?
