TSR long coding
Hi all. Is anyone would be able to provide me a list how to code TSR. My is activated but it doesn't work as it should. As I bilive it should work with speed limits from map where is no speed signs. It's only reads through camera instead of work with maps. All helps would be much appreciated. Thanks
TSR depends on the map data available for ur country.
Here in Australia, we don't have the necessary map data, ROW maps, hence we get a warning message at each start up, with only the camera detected speed signs shown.
Some countries have the necessary map data, hence will show either map or camera signs, or both.
Nothing u can do unfortunately.
Thanks for the reply. I'm in UK and I bilive that's should work together map and camera. I thought some could share list of long coding as I assume I make somewhere mistake while I was doing it. Sadly I didn't save previous settings. Also when I scan now it's showing me error of wrong coding.
