Pollen filter change how to?
Hi
Is there a guide on how to change the pollen filter on a roomster mk1?
In the passenger footwell, under the glove box, there is a long rectangular shaped cover under a textile trim held on with two plastic rivets. The cover may have another bit of textile trim over it but this should just pull off.
Slide the locking tabs towards the middle of the cover and it should come down revealing the filter.
Remove the filter noting the direction of airflow arrows or the direction of the slope of the top of the filter. Clean any leaves, insects etc with the vacuum cleaner.
Insert the new filter in the same direction as the old one came out, refit the cover and slide the locks back out to the ends of the cover. Replace the textile trim and plastic rivets.
Ta
