Engine bay water drains shuttle panel area
The skoda fabia engine bay water drains shuttle panel area.
So can you see the drains on each side or will you need to take the shuttle panel of to see its clear?
You might be able to see just by lifting the front (engine bay) edge of the scuttle panel. It might not be able to lift high enough to see without taking the wipers off by which point you're as well to take it right off anyway.
The drains exit into the wheel arches behind the inner liners though. So checking the other end isn't so easy.
Hope that helps.
