High RPM Idle?
Hello all.
glad to see the weather getting relatively better in London. It was a good 15-18°c today so it was nice to drive with the windows down a bit.
my Fabia 1.2 BMD engine has a slightly high idle. Wondering if anyone has any pointers to try and figure out what could be causing it.
The idle was at about 800-950
On startup, when warmed up and during drives.
the temp gauge is always just a bit over the halfway 90. And gets there fairly quick.
Any pointers are appreciated.
I've some notions, but would want a VCDS reading.
What’s the cheapest entry to this device?
Ive seen mentions of it around all the time, just not sure what to pickup exactly.
I also have a MacBook so no windows around me, although i could use a program to emulate(?) the windows and use my laptop or will i not need that at all.
Thanks mate
Thanks mate
You'd need to install Windows and use bootcamp on your Mac to run VCDS.
I had a trial for windows parallels once I may have to register again and try get another run of it.
Will try to update thanks for the responses!
