Clear Airbag Warning Light
I have tried one of those Android units in an attempt to improve my infotainment system.
However when removing the glove box I had to remove the airbag connector and now I am getting a light on dashboard .
It seems the code can be cleared with VCDS and noticed that it used to be a map with users  which could help but not sure if still active .
I have also seen that this can be cleared with a ODB11 so I can purchase one but there are so many of them and not sure which one to choose as on some it says they do not clear SRS /ABS errors while others seem to rely on software which is a bit of hit and miss
Any advice is appreciated
I have sorted the issue . I have bought a Carista device from Amazon and cleared it in couple of minutes 🙂
