Droning sound?
Anyone else aware of a droning sound?
On journey home from the dealership I was soon aware of a muted but constant droning. This was in marked contrast to the 'drone-free' 1.1 DSG Kamiq which I'd had for the previous three years. I've had the Karoq now for a few months and, with the exception of the droning, I'm pleased.
At this point I have a confession: Karoq test drive was exclusively in-town streets. Previous car was 1.1 Kamiq SE DSG. The three years with it had been a superb experience and I assumed the more expensive Karoq would be at least if not more refined. In some respects it is but the droning is a nuisance. And, I'm constantly aware of it at speeds above say 30mph. And it's not confined to spells in ECO ACT mode. It's ever present.
So, what's the source? Initial thought was the tyres. However, on different and varying texture surfaces the sound levels/frequencies change, but the drone is ever present.
Next thought: wheel bearing. Soon eliminated that by the standard check - left/right movements of steering wheel on smooth surface produces no change in drone.
I have discovered however, in normal driving if I drop the DSG into neutral the drone seems to be eliminated. I say 'seems' because it might still be there but masked. What I can say, for certain, in neutral I'm no longer aware of it. Of course that doesn't solve the issue in normal driving mode. So, is it the engine? Or, could it be the DSG?
I've not reported this to the dealership. It would be a waste of time. I can just imagine: 'We can't hear the drone you're referring to!'
Obviously, I'm not alone in this regard. The droning is referred to in the Skoda Karoq Forum.  So, is it an inherent issue with the 1.5 DSG Karoq? Or, peculiar to only certain examples?
What do you think?
Finally. Other than the drone the 1.5 DSG Karoq car is a superb machine. Eliminate this and I'd vote it most refined I've owned in over 63 years.
Edited by fabill
My manual 1.5 SEL Karaoq also drones on some road surfaces I Assumed it was the   tyres as the frequency varies with road surface. It occurs both with Bridgestone Turanza's ( Summer tyres) and Kumho (winter tyres).
So, not just DSG, manual too!
Just had a though: could it be resonance from the exhaust system?
Next outing I’ll select manual mode. That’ll let me extend revs which, if the exhaust is the source, will change the resonance hence drone.
I’ll report outcome.
Agreed, I've had several different cars which all exhibited some droning even on good road surfaces when they started to wear.
@fabill Have you checked the tread depths? Especially at the rear.
All rear tyres about 8mm tread depth so doI  not think it is caused by wear. My car droned from new!
Some years ago, as part of quite a few noise reducing measures on my 1.0 DSG Karoq SE tech, I attached a SS exhaust pipe short extension piece, bought from Amazon.  The original car was pretty quiet, but I do like car journeys to be as serene as possible and one noise source among several I was aware of, was a modest low frequency drone from the engine / stroke exhaust system, around 1500-2000 rpm when going uphill with engine working harder - otherwise, save the 1st minute idling from cold, the engine is unaudible (the 1.0 is said to be the quietest Karoq).  I saw that the exhaust pipe ended under the car rear and thought it might help to terminate further back + I did wonder if their was a risk of gases getting into the car through the rear hatch - no doubt a totally unfounded fear.
Whether this exhaust extension made a difference I don't know, but another modification that I've noted before in Briskoda, amongst the several I did - damping down the solid rear parcel shelf (mine thankfully isn't the roll top variety) with fairly heavy materials, almost eliminates that slight drone + also noticeably reduces road noise from the tyres. Of course scientifically one should do modifications one at a time, to really determine the effectiveness of any single measure, but I couldn't be bothered taking the exhaust extension off now, to check if it actually makes a difference.
Note with interest you have the 1.0L DSG Karoq. Moving from the 1.0 DSG Kamiq that was my preferred choice but, at the time none were available in the spec I wanted, hence the 1.5L.
Having read your post, if I could wind the clock back I'd have waited until a 1.0L came along. Other than some tyre noise normal driving in the Kamiq was pretty much a silent experience.
That was replaced only when accelerating hard by a non-intrusive thrum. I liked that thrum 😊
I'm now going to keep an eye open for a 1.0L KAROQ appearing at local Skoda dealership and book a test drive. That way I'll be able to experience first hand.
Anyway, notwithstanding, the Karoq is a fine machine indeed.
PS. Haven't tried the manual mode I mentioned in previous post. Will though and come back with outcome.
Edited by fabill
As above post, is it just the noise from the rear, roll up load cover rather than a solid one?
I'm in the throws of car hunting, Kamiq or Karoq not sure yet. One comment brings up more noise from the rear load area, re above comment because of the adjustable rear seats. Do all Karoqs have rear adjustable seats and roll type load covers?
Edited by MickA
No. Mine is SE Drive. Fixed non-adjustable seats and cord/moulded parcel shelf.
Fabill, you'd have to revert to a manual Karoq if you want a newish 1.0.  They stopped doing 1.0 DSGs in 2019, I just got mine in time that year and I couldn't go back to a manual. I'd go for a newer 1.0 DSG Karoq with even more bells & whistles than the SE Tech came with and was hoping they might bring out the mild Hybrid 1.0 DSG that was being talked at one time about. However that doesn't now seem likely, so I'm hanging on to my current car a good many years yet and that's no hardship. I must try a new 1.5 DSG sometime though, just to see how it compares.
Just looked at the Skoda brochure. The 1.0
https://cc.skoda-auto.com/gbr/en-GB/engine-scenic?activePage=engines&color=K4K4&configurationId=&extraEquipments=&id=GBR%3Bskoda%3B2024%3BNW4DQ4%3B0%3BGYOKYOK%3Bmda20240328103218%3Ben-GB%3B%3B61008%3B61528&interior=HN&modifiedPages=&snapshotVersion=297fde02-1373-481f-a2c8-610cc3ef4274&trimline=NWD|SE6152861008&visitedPages=trimlines|colorsKamiq is still available with DSG
2 hours ago, Routemaster1461 said:
Hi
That link is to the Kamiq. We were aware the Kamiq was still available in 1.0L DSG. croquemonsieur was referring to the Karoq. It's not available with 1.0L DSG.
Edited by fabill
Tried manual mode. Couldn't tell if any change in drone, as increased revs predominated.
One other thought has occurred. When I collected the Karoq it didn't have a spacesaver, just an inflator kit. I swapped that for a Kamiq spacesaver. It's not the same as the one for the Karoq - it's fatter. As a result the boot tray isn't seated around its outer edge, just sits on top of the tyre.
I'll remove the space saver and see if that has any effect on the drone.
I reckon it's definitely exhaust resonance
Removed space saver. Drone unchanged.
However, while coasting on a downhill, very, very smooth stretch of tarmac I noticed drone had gone. I tried accelerating and immediately the drone returned. Took foot off the pedal and drone disappeared.
I conclude from this that the droning is attributable to the engine/exhaust.
Ah well, don’t suppose there’s much I can do about that.
  • 2 years later...
Hey there, greetings from Lithuania.
Since I bought my new Skoda Karoq facelift 1.5 TSI DSG in late 2023 I had this road and booming noise a as companion in every single ride, which I thought is coming from the tyres or the suspension. However, after visiting the dealer, the outcome was that there is nothing wrong with the suspension itself and the tyres are brand new OEM Goodyear Efficientgrip Performance.
I tried to put some sound and vibration deadening materials on the boot floor right below the space saver wheel - it did not work and I did not notice any improvement.
However, what I have noticed, that the similar booming noise was coming from the boot electric tailgate when it was closing and contacting the metal hook at the end of closing and there was this boom noise. I added some sound deadening material on the metal hook, the tailgate started to close with a more solid sound and as a result the ride itself improved. I do not feel or hear any booming sound while driving and it really improved my driving experience. I also did notice the difference in how electric tailgate closed on 2021 year Skoda Karoq model, which my parents bought earlier and they did not face issues with the car, nor booming, their electric tailgate closes quietly, so if you experience something similar, please check your boot. Hope this solution can also help others.
The only droning I have in my Karoq is when I travel with the wife!
Do you think that it's the tailgate itself that is vibrating and causing the booming?
Our Karoq doesn't do it, but we also have a 1.0 manual Ateca and that booms painfully on rough surfaces at low speed - so I assumed it was the tyres.
Skodadriver88. Would it be possible to attach a photo of the tailgate metal hook with the sound deadening you added to it - I'm intrigued, it would seem that the tailgate does vibrate and your deadening helps isolate the vibration transmission.
I similarly found that adding sticky pads to the boot floor didn't really reduce noise from the rear, but i did find that ensuring parts of the spare wheel were firmly pressed against the boot floor through firm foam pads, did reduce the noise. I briefly experimented with really firmly tightening the spare wheel down via the wheel nut, but it seemed that slackening off just a little reduced noise a bit more, but can't be 100% sure about this.
I refer to my 28 March 2024 message about stiffening the underside of the rear parcel shelf with timber battens and weighting down the top with heavy mats was effective, but maybe a bit inconvenient if you want the parcel shelf to rise when you open the tailgate and only works on the rigid type fibre shelf that comes with with non removable rear seats.
Recently changing the shock absorbers to Koni Special Active (they soften up when wheels hit sharp ridges) did reduce bump thump and and also road noise a bit more and there were modest improvements overall to the ride. Interestingly a previous vibration under the dashboard, which seems a common Karoq issue, disappeared when the new shockers were fitted, showing that maybe less vibration is now passed through to the cabin. However not a cheap modification and I only did it, as the car is 7 years old and I want to keep it a good few years more.
One thing not mentioned. I noticed a droning on occasions. Then I realised that when it happened to eco symbol was on the dash. Turned out it was just a different exhaust sound when it was running in 2 cylinder mode.
On 07/06/2026 at 23:26, Rory said:
I just changed tyres to Continental EcoContact 6Q and it feels a bit less road noise, however, the dronning/booming sounds that are coming when driving over bumps or uneven asphalt surface was still there until I made this fix with the hook of the electric tailgate. Today I am going to visit the dealer and ask whether they have any better solution than putting sound deadening material on the hook itself. The dealer said there are problems with this sound coming from the boot on Škoda Octavia, but never heard of it on Karoq.
An update after visiting the dealer. The dealer did confirm that the electric tailgate was not properly configured. They did make a video recoding on the operating tailgate and sent the video to experts. The mechanic adjusted the hook by lossening the screws holding the lower boot hook and now there is no more that terrible sound.
Actually, there might still be something in that tailgate sound hook sound deadening business. I tried similar with my manual tailgate using a bit of thin foam sheet wrapped around the bar that the tailgate catch hooks onto. Also put some of the same material around the adjustable stops on the side of the tailgate and there has been a further modest but noticeable reduction in road roar and thrumming over sharp road ridges. Panel resonances can be a subtle phenomena and whether I've reduced vibration transmission to the tailgate panels or whether the tailgate movement was driving panel resonances in the main car body, maybe a bit of both, but partial isolation of the transmission has had some effect. The foam won't last long though before it shreds. Also the noise reduction may only be noticeable following all my other obsessive noise reducing measures I've undertaken.
I had a drumming noise from the front of my Karoq, had Skoda crawling all over to eliminate everything. Could not cure so ended up returning the car and changing for another car. Frustrating as I lost some of the nice spec that the original had and the replacement did not.
