Post cat Lambda. Heater circuit. Ecu removal.
ECU thrown a P0141.
post cat sensor heater resistance too high.
New sensor.  Same problem.
Next part is to test the wiring from the lambda plug to the ecu.
how the **** are you supposed to get the ECU plug off?
it’s got some sort of chastity belt on with two anti-tamper screws!!
With determination!
I dont know the set up or access on your vehicle but I have I the past angle ground screwdriver or spanner flats on them, not so good when next to the windscreen, or got them moving with a sharp chisel applied tangentially.
I have a recollection that when I did it on the MK2 Octavia I managed to bend the thing out of the way possibly after removing one bolt, to release the connector and then withdraw the ECU.
