Retrofit Taillights no facelift
Hello Guys. I have a question if you were kind to reply me
I have a Sulerb 2018 with normal taillights (non facelift) and i want to change them with this with square ornaments inside ( chech image)
This operation is plug and play? or need to be coding? Thanks
Edited by Razvann
fault on writing
Which lights do you currently have?
there are:
low line
high line
Full LED
If you are moving upwards then you’ll need coding and new wiring mostly.
low to high means that you’ll now have more bulbs on the tailgate so would need wiring and coding
high to led means adding new wires to the bcm and custom coding.
