Wolfbox dash cam mirror
Need a piece of advise.
Finally managed to hardwire the WolfBox dash cam.
Not sure if used the righ fuses though.
Everything works but... Just wnat to double check.
Had to attach 3 wires:
1. Ground - went on a metal scre on the internal casing of the glove compartment
2. Yellow - always on - Went for the 12v cigarette lighter fuse (piggybacking)
3. Red - on when yhe ignition is on - went for the rear wiper fuse (piggybacking).
Was trying to determine using micrometer which fuse is off when the engine is off but the tester was beeping at every fuse 😅
Please share your knowledge 🍻
