Emergency start procedure
Does anyone know what the emergency start procedure is? No power or lights to dash and not starting when turning key. Trying to scan codes but getting messages that ignition not switched on. I was looking on Ross tech site and it seems there’s a procedure where you operate some things at same time or in a sequence like hazards, brakes or wipers and it fires the ignition up so you can read codes. But can’t find what procedure is, anyone know?
There is no emergency start procedure.
Hello Ken, is your battery discharged - or is there some fault with the ignition switch?
A good battery and being sure of well connected then the main fuse checked is a good way towards chance of starting the engine.
  • 4 months later...
Hi
Check the fuses, especially for the dashboard (there are 2 under the dashboard!) and the canbus in the engine compartment under the hood !
