Faulty oil temperature sensor
Hi guys. Does anyone know  oil temperature sensor and oil level sensor are in one or they are separate and where exactly the oil temperature sensor is located. My one is faulty and need to be replaced. Thank you
Hi,
I think they are the same. But not 100% sure. 🤔
If they are, it's located in the oil pan under the engine. it can be removed easily with only 2 torque screws (if I remember well) once undertray has been removed. BUT, you have to drain the engine oil first, otherwise, you'll be showered with engine oil. I had replaced it on my wife's Audi Q3 TDI150 (due to a misunderstanding of a fault code. the sensor was OK, but the harness had been bitten by a rodent 😬)...
Thanks pal. I am gonna lift the car and have a look tomorrow.
