Where the sound comes from?
Hi welcome,
I could not hear the noise clearly but it is more likely to be associated with your steering or suspension (even tyre(s) perhaps.
What makes you think it has anything to do with the gearbox?
Gearbox oil change is the solution for me. Thanks.
You don't put what make, model or year of car you have, do you mean hydraulic fluid for the power steering fluid rather than transmission gearbox fluid?
2015 Skoda rapid spaceback 1.6 tdi 5 forward manual gear car.
transmission oil change.
didn’t Do anything with power steering cause i have only electrical.
Did the gearbox oil change make any difference to anything?
Too late now but for gearbox oil change but I always recommend doing a hot, long drain, with at the end a small flush-rinse of warmed fresh oil and to use a very good quality of silicone gear oil as it is not a job you do often and the difference in cost is not much overall especially given how long it lasts.
If you are interested you could add your car details to your name thingy, as an example only mine is below.
