6q2959802 compatibility
I see there are different type of window motor in the Skoda. Also, the one with this reference 6Q2959802 has three different letters: 6Q2959802A, 6Q2959802F and 6Q2959802J...
Do 6ou know what is the difference between them? Are they compatible?
Thanks!!
  • Sponsor
Google images helps.
6Q2959802A is an earlier CAN-based variant with 3 separate connectors.
-F and -H are both LIN-based, single 16-way connector types for cars with front electric windows only, but one connector is at a different angle to the other. Depending on loom length and clearance/space behind the door card, these might be interchangeable.
Suffix -G and -J are for cars with all four windows electric, again with different angles of the 16-way connectors.
Best to buy a perfectly matching part number.
Thanks for the reply! Very clear! So I'm worse case I do  it find same reference 6Q2959802F the best choice is 6Q2959802H that would need only connector adaptation, right?
Second question... is it possible to identify the reference without label? There is any link between the reference number 6Q295... and the QR code? Thanks a lot!!!
  • Sponsor
Yes, you could possibly swap the right-angled connector part and straight part between original and replacement, if the loom won't reach, or the door card doesn't have the clearance behind it. They come off quite easily. I think they'd be interchangeable, can't find a straight one to try at the moment.
I'm not sure what the QR code might tell you, try decoding it and see what it says?
  • Sponsor
The suffix G or J might well work on cars with only two/front electric windows, but obviously an F or H won't do all four on a car that has them.
Thanks a lot for your support!! Very usefull! I am having problems to find the same reference 6Q2959802F... and I think I can try to find other 6Q2959802 - (F,G,H,J)! I found this one but the provider told me that there is no reference in the piece. It seems the same I have... But not sure if it can be a different part number from the four above mentioned... this is why I saked about the QR code. This is for one Skoda Fabia III Combi 1.0 2014.... what do you think? Thanks a lot!!
  • Sponsor
That one will be a 6R0959801M, next generation, not compatible, I believe.
Same for anything built after mid-2010.
Edited by Breezy_Pete
Thanks a lot for the advise!!
Hi! I found a 6Q2959802G. I installed it and both windows work again! Thanks a los for supporting. Very useful.
BR
