Rear near side door lock cable
Recommended Posts
Should the plug that connects to the rear central locking be so hard to connect. Lot of force needed to push the fitting to get it to click in position.??
Link to comment
Share on other sites
It should, however if you want to make it easy simply remove the ribbed silicone rubber seal, grease up the plug with some vaseline to repel moisture and snap it into place.
Link to comment
Ok, thanks. Was wondering about that. It seems that the little clip that holds the plug together is under a lot of strain, so will remove the seal , just apprehensive without asking. Thanks for your quick reply. Obliged
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
