Oil pressure switch
Hello everyone,
I have my oil pressure warning light illuminated, there is enough oil in the engine and the oil pressure gauge shows 40-50 psi of pressure.
Also engine sounds fine running,do you agree with my thought that the pressure sensor is kaput?
  • Sponsor
Probably, or the wire to the switch is broken. Which engine does you mk2 have?
My car has the 1.2 3 cylinder engine.
The wiring looks ok on the switch.
It went off for a while yesterday but is on again today, still good pressure showing on the gauge.
  • Sponsor
If you unplug the 1 wire connector from the switch, is there oil inside it?
That's usually a giveaway that the switch is failing.
Presumably you mean an external pressure gauge plumbed in in place of the switch? Or?
Edited by Breezy_Pete
