ODB2 software ??
My daughter recently got a 2010 (59) Fabia 2 1.2HTP.
I have a bluetooth and also USB wired OBD2 reader. In the past I have used FORSCAN for ford cars, this is a free downloaded software is pretty good. Is there a specific software for Skoda/VAG of that age?
The issue I want to look at is a very slight misfire/judder. Particularly noticeable when it is sitting at idle. Every 45/60 secs or so the revs drop a bit and it gives a judder/shudder, then idles ok.
I am not sure when it was last serviced or plugs changed, but I want see if there are any error codes before I start changing things.
Ross Tech VCDS running on a laptop. VCDS Lite is a free download. I have it on my laptop but have never tried it.
Thanks Jocko.
Looking at the Lite download, it says for 2005 and older vehicles... I take it it will still work on a '10 ??
  • Sponsor
As long as your mk2 was built before March 2010, Lite should be compatible.
If you don't know exact build date, message me the reg or VIN and I can find out for you. Won't be til later on this evening though.
I will download and give it a go.
