AC clicking coming from dashboard
Hello :)
Recently started noticing this issue, it is present only when desired and ambient temperature meets each other (like AC is set to 22 and there is around 22C inside). Sometimes it comes from the glovebox area, sometimes from driver area. Lowering temperature setting fixes the issue. It is not loud but it is annoying as hell, especially during long rides. In service they say that "they hear nothing" and "everything is working fine". Any ideas what can cause this issue? Recording attached: IMG_9080.aiff
Thanks!
Edited by roki11
Hey,
Have a similar issue - whenver AC (or well - fans) are working, you can hear buzzing/motorry sounds coming from the fans under the front windshield. It's very intermittent, sometimes louder, sometimes barely audible. And only audible in silence, i.e. when no music is playing.
Asked the dealer - it's essentially actuators and gears moving the fan blades side to side and controlling the airflow. There is no 'fix' for it, other than completely disassembling the whole front panel and lubing them up. It's not 'repairable' and is not harmful.
Anyway - yours is slightly different issue. I'd suggest keep poking the dealer if it's under warranty, otherwise seek other repair shops.
