2015 CFJA Audio unit cables help
Hello,
I have an RNS315 unit in my Yeti.
I have purchased an xtrons unit to replace it with.
I want to know which cables in the car are which.
As in which one is radio, which one is DAB, and which one is GPS.
My aim, if possible, is to use the existing cables and connect them to the new unit, rather than connect the new antenna to windscreen and such.
Bad pic of the 3 cables disconnected from RNS315 attached.
I think  white one at the top is the radio antenna, which does FM and possibly AM radio.
Which one of the remaining two at the bottom is which (DAB, GPS) please?
Thanks 🙂
OK, so I've found a helpful pic elsewhere that shows the pinouts.
I've managed to get FM radio sorted with the supplied cables, wires, connectors.
Now just need to see if can use the existing DAB antenna, so I don't have to faff around with running cables behind glove box, and up the inside of the pillar, and sticking it on the windscreen.
Not concerned with the GPS antenna connection too much as I'm using Android Auto, and it seems to be picking up the signal via my phone's GPS.
