2015 Mk 2 1.6 TDi Fault code P0401 00 [11101000] - Insufficient Flow
My tales of woe have now extended to my car. I can't recall the last time one of my Superbs was in good health since my wife bought a Mk 3. This time it is my Mk 2 estate which is showing teh fault below. Needless to say the EGR, from what I read, is tucked away 2 or 3 hours labour from removing. I used to clean out my Mondeo one regularly  but that was right at the front of teh engine. I'm presuming the egr is clogged up but I dare say it could be a hose with a leak. Car running perfectly and can't see any smoke. Any suggestions or is it yet another holiday for my mechanic at my expenses lol
Sunday,30,June,2024,19:05:13:03968
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 24.5.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20240429 DS355.0
www.Ross-Tech.com
VIN: TMBKJ73T6F9054248   License Plate:
                Address 01: Engine       Labels: 03L-906-023-CAY.clb
Control Module Part Number: 03L 906 023 PR    HW: 03L 906 023 JH
  Component and/or Version: 1,6l R4 CR td H43 6942
           Software Coding: 00194014032501080000
            Work Shop Code: WSC 33361 790 00999
              ASAM Dataset: EV_ECM16TDI02103L906023PR 003004 (SK46)
                       ROD: EV_ECM16TDI021_SK46.rod
                      VCID: 055781ECA5A1DE22645-8050
1 Fault Found:
7337 - EGR System
          MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 30
                    Mileage: 239698 km
                    Date: 2105.14.30
                    Time: 14:08:20
                    Engine RPM: 1723.75 /min
                    Normed load value: 9.4 %
                    Vehicle speed: 100 km/h
                    Coolant temperature: 92  C
                    Intake air temperature: 19  C
                    Ambient air pressure: 980 mbar
                    Voltage terminal 30: 14.456 V
                    Unlearning counter according OBD: 40
                    Air mass: specified value-MAF_SP_MMV: 235.75 mg/stroke
                    Air mass: actual value (mg/stroke)-MAF_MES: 349.841 mg/stroke
                    EGR Solen.val.: actual value-ANG_EGRV[0]: 84.021 %
                    Throttle valve adapter: actual value-ANG_THR[0]: 95.996 %
                    Charge air pressure: specified value-MAP_SP_MMV: 1074.28 hPa
                    Charge air pressure: actual value-MAP_MMV: 1074.28 hPa
                    Engine torque-TQI_SP: 39.63 Nm
Readiness: 0000 0000
Just to update on this. The light went off itself. I got the car Carbon cleaned and so far no further light and car running fine.
  • 1 year later...
How long before the light came back on after the carbon clean ?
I haven't done a huge amount of miles since then (8k or so) but haven't seen it since. I do have a similar code on my new to me mark 3 so may well go down the same route for that and get a carbon clean
Edited by wookie67070
