ABS ring
Hi all, I have a Fabia 1.2 60bhp and ABS light is on. Diagnostic say front left ABS sensor so I replaced but warning still on. I think its the ABS ring but i am struggleing to find part number. Can anyone help me please.  Reg YF08 HGO Thank you
  • Sponsor
It's part of the wheel bearing, unfortunately; and not a simple job to change that either.
I wondered why wheel bearings kept popping up on the search. Ive a wheel bearing removal kit so will order new bearing. Thanks for your swift reply Pete
  • Sponsor
Be careful when buying bearing, there are two different ones depending on brake system type.
I'll grab correct part number via your reg in a minute.
ECP and their ilk will probably offer both correct and incorrect parts.
  • Sponsor
You have the smaller discs (front brake PR=1LB), so the part number to buy/match is 6Q0 407 621 CB.
The more common one, for 256mm discs has a larger hub section that won't fit inside your discs,
Is the fitting kit you have suitable for Gen2 wheel bearings?
Thank you Pete and funnily enough I was changing my bearing on my MK1 VRS a couple of years back and I bought the wrong bearing. I did not send it back. Just looked on shelf and there it is with the correct part number for mine. Lucky me.
