Roomster blower motor problems
Hi All,
I have a 2013 1.6tdi Roomster with standard air con. Recently most of the time the heater blower motor does not work but will occasionally. Also the interior/exterior air switch is intermittent but the air con does not come on at all.
Fuses are OK. And suggestions/guidance as to how I can proceed with fault finding would be much appreciated. What is the best way to access the relays which I believe are near the fuse box - do I need to remove the fuse box for access?
Kind regards,
Andrew
