Increased fuel consumption after service. Karoq Sportline 2023
I travel 500km a week. Same route. Have done for years. I generally get 700km a tank on 98 fuel. I had my car serviced and immediately drove to my destination. I thought the instantaneous fuel consumption appeared to be higher than normal going there (which is mostly downhill). My suspicions were confirmed when red light came on as I got back home - having only travelled 500km. The infotainment system showed I averaged 12l/100km (normally around 7 or 8). I took it back to the service guy who said it was due to idling in the shop. He didn't seem to understand, regardless of the computer reading, I used a full tank (I know I did, because I refilled and it was definitely empty. I see a few others have had similar questions but I couldn't see a resolution?
Welcome.
Have you filled up again since and got as bad fuel consumption.
If so what was what was done, did the car get new spark plugs, air filter and a software update,  Oil & Filter.
Sitting idling certainly can use plenty of fuel. If idling long enough.
How ling was the road test the guy / guys at the shop went on?
He said it idled in the shop but I don't see this os relevant if I filled up after the service and immediate embarked on my usual trip. I have refilled and will set off on my weekly trip soon. Will be interesting, but I'm worried I'll run out of fuel if it problem gets worse. The place I drive is remote & fuel very expensive. It was a standard 30,000 service as per the service pack purchased with vehicle.
Thanks.
Now i understand. Fuelled and reset and just 500 km from that tank.
What is a standard 30,000 km service in Australia then, the same as in the UK.
A variable / flexible service, 18,000 / 20,000 miles / 24 months, An oil & filter change & look see?
Was the oil used to VW508 00 / 509 00 then, so 0w 20 FS IV.?
I assume no mention of any Software Update then.
1039190636_Screenshot2021-09-29at07_53_36.jpg.994d2b104123865330d493df0f73629e.jpg.4060614ecaf863724d77483ade91b368.jpg.28435338a81181598fdb696be111df00.jpg
1025295341_Screenshot2021-09-29at07_53_17.jpg.f3e4a6dc63cb89105f9b1ac440bb1614.jpg.4ed61f3b03cbb7d9a31e7e6cdc3c1db6.jpg.8789a4a4559f4b69e532e36a77ad634e.jpg
1179912860_922218293_Screenshot2022-09-2115_58_57.jpg.3711dc86397a804fc83f268add4ae736(1).jpg.606196879c2532f67305f1ec411800c6.jpg.89cf6ebb24d12af4764aed8c2abcd43d.jpg
Edited by Ootohere
So update...I continued using approx 12l/100km of fuel. I filled up again (3rd time since service). Instantly,the fuel consumption dropped and righted itself (back to 6- 7l/100km). So, it must have been crook fuel, not the service (coincidence!) First two lots of fuels came from 2 separate servos but same town. The 3rd 200km away. Thanks for advice but all seems well now.
