How to unlock MIB 3 Preh with patch...
Hello everyone. Would it be possible to unlock MIB 3 with patch in order to have a totally unlocked system and apply all the Fec/SWAP codes with OBD 11? Do any of you have a guide with files in this regard? FW version MOI3_EU_SKMQB_P30800P version
AFAIK it is not possible, at least publicly known.
Hi. At the moment the patches stop at MIB 2.5 the 3 is still unknown and armoured, better to make the updates at least to version 330
 too bad... with the latest update I lost navigation and I saw that the code 00071c00 must be enabled with odis-s. Would it be possible to do it also with obd 11 and above all how do I get the swap code for the predictive navigation function?
I'm pretty sure someone on this forum has explained what to do in this situation. The same person also provided an Excel document with all VINs and respective codes for activating the missing navigation. However, you'll have to go to a dealer for an activation.
The link is still valid -> MEGA
I already followed this guide and it says to use ODIS but I don't have it and I wanted to know if it was possible to use obd 11 and if so, if there is a guide. I have the 91GB file as indicated in the guide you posted but I don't have ODIS
That's why you have to go to a dealer or someone else who has ODIS. If the car is under warranty, they'll do it for free. Otherwise, you have to bargain for a fair price.
you necessarily need the ODIS 23.0.1 version with VAS6154 as indicated in the pdf attached to the posted guide or you can use an older version of the software as well as the OBD2 hardware
You can try it. I have never done it, as I go to the dealer for those things since my car has a prolonged warranty.
Ciao Have you update the OCU?
TPI-2060553-8.pdf
Edited by GiscoYeti
I don't have ODIS. Would it also be possible to update it via OBD 11 or via USB?
I finally found Odis and followed the procedure to enter the codes. The process is not successful because the software requires me to access online which I do not have. How do I fix it?
We can reinstate this for you
You’ll need an independent specialist such as ourselves, or you’ll need to visit your local dealer
Compré la solución De mqbcode por 2000 euros, refiérase a ella, Lo encontré aquí Squader
Edited by Fill
there is already publicly available patch.
WHERE? could you put a link thank you!!!!
Try to search "fec swap moi3 preh" in drive2 of russians.
No odis needed  this way
Edited by vegarz
