Can anyone recommend a good supplier for Audi S3 front brake discs please?
Morning guys, looking for some drilled S3 front discs for my Mark II facelift 59 plate if anyone can recommend a good brand and supplier please I would be grateful 👍🏻
Have you considered ATE PowerDisc front brake discs, as shown in the photo below? In my view, they look more high tech than the drilled Brembos. However, I haven't seen ATE PowerDiscs for the rear 310x22mm brake discs...whereas I have seen Brembo drilled rear brake discs in that size.
Here's a photo of an ATE PowerDisc 345x30mm front brake disc. It has a minimum wear of 27mm, which is about 36% more wear than the below drilled Brembo front brake disc.
530115 ATE PowerDisc 24033001151 Brake rotors Audi A3 8P S3 2.0 quattro 256 hp Petrol 2011 cost uk
Here's a photo of Brembo 345x30mm drilled front brake disc. The minimum wear is 27.8mm, so you would get over 36% more wear on the ATE front PowerDiscs before they needed replacing.
BREMBO Front Axle, 345x30mm, 5, perforated/vented, Coated, High-carbon Ø: 345mm, Num. of holes: 5, Brake Disc Thickness: 30mm Brake rotor 09.C892.1X buy
https://www.autodoc.co.uk/brembo/13801758#brake-disc
Edited by Carlston
