Low coolant level warning light
Hi Guys
Quick question, I have a Mk3 Superb 2.0Tsi Sportline, 4 years old, extended warranty. I have a warning light on for coolant. Not overheating, no sign of any leaks
Seem to re set with ignition, lights up every couple of days, twice today. Pretty sure it's a sensor, any ideas comments before I swap it out (and I assume it's the one on the header tank lid )
Thanks in advance
M
Have you checked the level?
Is it close to minimum, but say if you park on a slope the level may change slightly?
Hi John1701
Good shout, my driveway has a gentle slope and I've checked the level and it is below the line.
However, the light doesn't come on as I drive off, but during driving, some days not at all but twice yesterday
So, I'll top up the fluid and see what happens and report back
? Where did the fluid go, in a sealed system ??
Update. Popped into the local Skoda dealer and purchased a litre of premixed coolant for £8, put in half a litre, wait and see ?
Still can't see a leak though ?
If it drops again check for coolant under the inlet manifold and any signs of it below that on the sump. 2.0 tsi has a habit of leaking from the water pump.
Good to know, I'll keep an eye on it, thanks!
