Door rattle while playing music
Hello,
i recently bought a 2019 Octavia L&K, and noticed there is alot of door rattle while playing music. Am taking it to the dealer next week, but has anybody had this exact problem resolved before? Also Skoda connect dont work.
  • 4 weeks later...
Which door?
Window controls in my driver door (for all windows) are loose and rattle with music even at relatively low volume.
It will probably be one of two things.
If you have an L&K, you should have a Columbus system.  Check exactly which door the issue is coming from.  Is the rattle on the tweater at the top of the door or the mid-range in the middle bottom of the door?
Its a possibility that you have a blown speaker.  Failing that, it is also possible that the rivet holding the speaker to the door has sheered (this happened on our 2020 Golf) and also caused water to get into the cabin.
Which ever option it is, its a door card off job to investigate.
I think that may only be true of a FL, my 2016 PFL L&K has an Amundsen.
