Xenon auto levelling headlight unit
My 61 plate diesel yeti has failed the MOT as the near side headlight doesn’t come to rest at the correct angle.
Garage says new unit £680. All cheaper ones that I can find on eBay etc are right hand traffic.
Is there a cheaper fix?
Thanks.
Not sure, how do you determine that? Thanks
I don't know either - speak with the garage doing the mot - they should be able to tell you.
I had a 2009 Subaru where it was the height level sensor rather than the headlight itself and I fitted it myself. It had rusted and become detached / loose.
Edited by Prezafab
Thank you, greatly appreciated.
IMHO I don't think it could be a fault with an axle sensor, as AFAIK there is only one sensor each at the front and rear, so if either was to be faulty both headlights would be similarly affected?
