Felicia Mk2 1.3 Thermostat
On 29/10/2024 at 13:56, Thefeliciahacker said:
topran is something worse than crap
Better than nothing.
If you remember you were bragging that a car does not need (!) a thermostat and you have removed yours, no problem etc.
After few months you blown-up you gasket and you forced to install a thermostat.
On the contrary, the removal of the thermostat postponed the inevitable.
The vehicle was overheating due to HG leaking, The father asked me to provide a solution thus I removed the thermostat, as HG leaking progressed so did the symptoms and it reached a point where it couldnt be mitigated by anything.
At that point, the vehicle was owned by me, and the refresh of everything commenced.
This means HG change + radiator + 2speed fan + thermostat and so on.
So if the vehicle was in okay shape I would have kept the thermostat from the very start, but if I had done so with leaking HG the failure would have come 2 years earlier.
Edited by Thefeliciahacker
On 29/10/2024 at 15:44, jbedford said:
 I'm putting a Mahle in it and hopefully that will solve my woes.
You bought it? Cost?
Not yet, will let you know.
