Niggly intermittent issue solved
I was experiencing an occasional (once out of 20 ish) "non function" of the wash wipe (when you pull the wiper stalk towards you), I determined
1, The fluid reservoir had fluid in
2, The washer nozzles weren't blocked
3, The pump was fully operational, this lead me to the conclusion it was Stalk related.
Removed the airbag and steering wheel, removed the combination wiper / indicator stalk and fitted a second hand unit
This has cured the issue, on disassembly of the switch unit I cant find where the pull to wash switch is in the innards ?
But I don't think I'll pursue any further as its working now (I was going to clean (said switch contacts))
Edited by Crucian
