A/C & Heated screens issue RS230
Hi all,
I have a bit of an issue after developing with my 2016 RS230 combi and wanted to know if anyone else has had a similar problem.
As soon as the car is turned on the external ambient temperature shows as 60°C.  There is no fluctuation in this and it shows up as soon as the key is turned in the ignition.
The heater (both in normal and A/C mode) is also blowing cold unless turned to the Hi setting, in which case heat is emitted .
Also both the front and rear heated screens will switch on (power goes to the button) but switch off again after 2 seconds.
The car has the winter pack, and the heated front seats seem to be unaffected.
The car also has a FSH with Skoda and as a matter of note has only recently (last 2 weeks) had both the altenator belt replaced and a replacement pipe to the coolant reservoir installed following the development of a crack in a the system which caused the entire resevior to empty (luckily this was found immediately).
Any ideas? Thanks...
Hello, I'd get the external temperature sensor tested as it has probably developed a fault - this could very possibly be affecting your cabin heating system, as the system will think that there is no requirement for hot water to be supplied to the heating matrix. I wonder if your screen heaters are also being misled by the same anomalous external temperature reading.
