Glow plug control unit issues
Morning all
thank you for letting me join.
I have a superb estate 2.0TDi 150bhp (2018) with around 100k miles on the clock.
Check engine light game on -
checked battery voltage and appears to be fine
OBD2 code indicated glow plug control unit so replaced. code cleared. A couple of days later the fault appears to be back.
I have read it could be the glow plugs or wiring.
so was wondering if others had been this and what they had found to be the cause so a target steps logically.
many thanks
rolo
Error code pls?
1 hour ago, ile7 said:
Error code pls?
P064C which comes up as glow plug control unit when a search for it
Did you change 527 relay?
Edited by ile7
Yes I did, fitted a new one. Cleared the code and 2 or so days later it has come back
  • 2 months later...
Just got the same error myself, did you ever find the answer? Also did you have any issues with the engine starting? I have keyless start which sometimes doesn't fire
