Knocking noise when clutch depressed
Good afternoon one and all,
   After some much needed help and information. My Mrs drives a 2013 Skoda yeti 2.0 diesel 4x4, just over 60k on the clock with full service history.
So yesterday whilst out driving only a relatively short distance we noticed a knocking noise (audible from inside the cabin) only when stationary and in first gear. Car still drives spot on and smooth through the gears. We parked up turned car off and on again the noise went away... She then popped to the shops this morning again car drove spot on to the shop but on the return trip it started doing it again, once she returned home I went to see if it was still doing it and nothing (I wanted to film the noise if I'm honest).
Can anyone please shed any light on this issue? My first thought is clutch release bearing? Even if it was just that I'm guessing gearbox would need to be taken out to replace? So probably advisable to replace clutch and dual mass flywheel at the same time? Any idea on the cost of this part and labour? I have a trust worthy mechanic who is reasonably priced just he's off until the new year so don't want to bother him.
I have advised my other half not to use the car for now.
Any help or information greatly appreciated.
Thanks in advance
Sorry if in the wrong topic
Hi, welcome.
A video of the noise might be handy.  At seeing the words dual mass flywheel that would be my first thought but that might just be my bias.
You might get quicker better responses from looking in and/or asking in the 'Škoda Yeti' forums, link to follow.
If you have parked the car up do take the opportunity to fully recharge the car's 12v battery with an appropriate battery charger otherwise you could get another problem with the car and the breakdown services, lots of garages, mechanics and auto-electricians will already be busy with cars where the owners have let the car's battery go flat over the Xmas break.
Also if you want to add more details to your name-thingy then those viewing on computers will see the details each post which can often be helpful, mine below only as an example. -
'Škoda Yeti' forums - https://www.briskoda.net/forums/forum/170-škoda-yeti/
Good luck.
