Boot button on key fob and centre console
I've just purchased my skoda superb estate hybrid. The boot button on the key fob and centre consol does not open the boot.
Has anyone else had this issue and know how to fix it?
Also does the 2021 model have the virtual button under the boot ie wave your foot under boot?
Depending on the model, some keyfobs will only 'pop' the boot lid rather than raise it.
Mine is skoda superb estate 1.4 TSI iv SE L DSG 5dr
Does yours have electric boot? Being SEL it should.
For the key, I take it you held the button down and not just pressed it once, and tried on spare key?
What happens when you open it manually by pressing the button on the actual boot?
Could be motors failed but after 3 years seems unlikely
My boot opens automatically when I press the boot button on the bit and closes when I press the boot button on the boot.
When I press the boot on the key fob the lights flash but it does not open
Edited by FireXtinguisher
Hmm there isn’t a way to disable the fob from opening so that suggests the actual key is at fault, try the spare key and see if you get the same.
Hold down boot opening button for a few seconds.
As for virtual pedal not sure, reading some peoples stories on here it’s hit and miss I believe, but one thing at a time and start with fob
Are you holding it down for a couple of seconds?
  • 4 weeks later...
Thanks all for comments. All sorted, thank you
Would be good to know how.
Error with the key fob, all sorted 😀
