Please help with Coolant temperature sensor problems
  • Sponsor
Could also be that the original sensor suffered a perforation failure which caused coolant to go into the connector pins, and may now have travelled along the strands of the wires to the ECU connector.
If you find wetness at pins 52/53 you will know for sure.
Error seems to be found. Damaged wiring. Colors of wiring fit to sensor wiring.
Seems to happen quite often exactly in this spot.
I'm going to repair it and will give feedback
Problem solved! Thank you all for your help!
  • Sponsor
Excellent, thanks for showing us the damaged area.
