Skoda Roomster 2008 1.4 16v engine wiring needed problem with camshaft sensor
Hi guys could anybody help me with 1.4.16v engine wiring to get clear some thing about crankshaft and camshaft position sensor...I have fault P1337 vcds 17745
already tryed new sensor,swap another ecu, checked timing and also wiring from to ecu
car start very hard long crank
what is wierd that have one wire with ground ,one with 5v and last with 5v also where one could be signal from sensor to ecu
thanks for any help what else I should check
cheers
