DSG7 DQ381 coasting
I've tried with both VCDS and OBD11 and failed, I cannot find the darn "sailing_off" option in the adaptation list. Very frustrating. I need to extract my screens and see where I am not seeing what probably is in front of my eyes ....
-> https://www.briskoda.net/forums/topic/516414-vcds-options-on-superb-iiifl/
On 07/09/2023 at 10:05, MartiniB said:
Disable DSG coasting(sailing) function on Normal profile
19 Gateway module
            Long coding
                        0B0900047F285900AB1042DE980F00010001070000000000000000000000
            ->         0B0900047F285900AB0042DE980F00010001070000000000000000000000
or         -> FPA_function_freilauf_defaultON
                        active   ->         not active
Rather surprisingly it is in the CAN Gateway module.
Just to check, wer're talking about you being in any driving mode other than Eco, aka there isn't any actual coasting?
The grinding noise likely needs some more looking at, however it does also sound like it's partially just the nature of the gearbox. I have a DQ381 and even with a TCU tune, the car can still be very jerky if I suddenly lift off the throttle while accelerating a little in first or second. I've also experienced a bit of what you describe - at slower speeds (low end of D2), if I accelerate with a squeeze of throttle, the car can be very slow to feed the clutch in, making it a less-than-smooth experience as the revs rise.
To partially complement th comment of Occy above, my DSG sometimes 'jerks' or as I said, loses its attention and needs a moment to catch the right gear. BUT - this is wiithout grinding noises or clunks/thuds. The occasional 'bump' is noiseless.
I support the idea to have it looked at.
Thanks to all the comments above, will get to it in the next few days,thanks!
