Change USB-A to USB-C because CarPlay keeps dropping
Hello,
I’m having problems with CarPlay, the connection keeps dropping when making calls and if I’m using navigation I have to end the call to reconnect to CarPlay. Tried different cables but still the same problem
So I’ve decided to swap the two USB-A ports with USB-C to use the original cable from Apple.
My car is an Kodiaq 2018 with Amundsen updated to the latest firmware.
I have bought the USB-C ports(3G5035726).
I’ve seen that they(USB-C) have an extra pin then the USB-A connector.
Changed the ports and it seems to work for now, but should I change to the cable with the extra pin for USB-C?
Does anyone one knows the number from USB-C cables?
Is there any piece that I should change, any other adapter?
1 hour ago, andrei_horeica said:
Hello,
Have a look at this Wikipedia
