Buting a Skoda Octavia with a DPF delete
Good morning Liam, tena koutou, welcome to the forum.
It will really depend on NZ WOF requirements, the DPF serves to remove diesel particulates from the exhaust, but can result in issues with regenerations if the vehicle regularly does short runs. After a number of failed regens, the DPF can eventually become blocked, requiring expensive replacement - in the UK, DPF removal (if detected) would be a failure when the vehicle was in for its annual MOT test.
Edited by Warrior193
Add welcome
Take a look at the NZTA portal, sect. 11-2, paragraph 2. Unless the vehicle has had (and passed) an emissions test since having the DPF removed, it seems that it will fail a WOF test.
Thank you for your response, I will pass on this one and wait for something else to come up.
