Lane Assist / Passenger Door Fault
I bought a 2000 (according to the scan - 19 plate) Superb L&K about 2 month ago second hand. A couple of weeks ago the passenger door wouldn't open, either with the internal or external handles. Central locking seemed to sound like it was activating. The following week I started to get lane assist errors. Then the car went into limp mode + lane assist error on one occasion exiting a roundabout behind another car fairly rapidly. These faults appeared intermittent, then got worse. I ordered up an odbeleven to reset the codes. With everything cleared down the lane assist issue disappeared once and I could open the door. Then it reappeared next engine start.
I've pulled out the diagnostic info using the VAG app. Given that there's multiple issues around the left door i'm suspecting a wiring issue?
What would be the best way to diagnose this. There's still a month's worth of warranty on the car, so taking it in to be checked if it is a door lock issue is a possibility, though I'd rather trace it beforehand so I don't end up wasting time.
Error Logs:
OBDeleven data log
Date: 2025-03-27 16:41
VIN:
Car: Skoda Superb
Year: 2020
Engine: DFHA
Mileage: 149486 KM
09 Central Electrics
System description: BCM PQ37BOSCH
Software number: 5Q0937086CF
Software version: 0303
Hardware number: 5Q0937086BR
Hardware version: 038
Serial number: J53F060719002V
ODX name: EV_BodyContrModul1UDSBosc
ODX version: 020001
Long coding: 000000000000000000000000000000000000000000000000000000000000
Subsystems:
System description: 48x RL 280519
Software version: 0121
Hardware version: 032
Serial number: 00000001905230303625
Long coding: 165DDD
System description: RLHS
Software version: 0206
Hardware version: 051
Serial number: SBY19M07D16H04M40S43
Long coding: 0088DF
System description: Sensor, DWA
Software version: 0316
Hardware version: 005
Serial number: 000000000ZY19190093C
System description: Sirene, DWA
Software version: 0007
Hardware version: 004
Serial number: 00000000000000510142
System description: Lenks.Modul
Software version: 0170
Hardware version: H33
Serial number: 0100160720190C104301
System description: SysNameFanLin
Software version: 0101
Hardware version: 014
Serial number: ESE0542736
Serial number: ESE0651027
Serial number: ESE0932069
Serial number: ESE0651021
Trouble codes:
B1330F5 - Anti-theft alarm system sensor Alert - Emergency activation stage 1
static
13 Adaptive Cruise Control
System description: ACC BOSCH MQB
Software number: 5Q0907572R
Software version: 0771
Hardware number: 3Q0907567A
Hardware version: H01
ODX name: EV_ACCBOSCHVW416
ODX version: 003014
Long coding: 320467D359FFC728949C812480400600000000000000000046
Trouble codes:
U112300 - Databus error value received
static
3C Lane Change Assistant Right
System description: HRE3_Kl15_Mst
Software number: 2Q0907686B
Software version: 0149
Hardware number: 2Q0907686B
Hardware version: H06
Serial number: 00000522862771
ODX name: EV_HREntryHellaGen3Kl15
ODX version: 002001
Long coding: 92954640
Trouble codes:
C122C11 - Blind spot recognit. warning lamp in left ext. mirror Short circuit to ground
static
52 Passenger Door
System description: TSG BFS
Software number: 5Q4959592K
Software version: 0480
Hardware number: 5Q4959592K
Hardware version: 007
Serial number: 0000383507623
ODX name: EV_DCU2PasseSideMAXHCONT
ODX version: 001005
Long coding: 001D8020DE01020000001100
Trouble codes:
B122B12 - Central locking motors Short circuit to B+
static
B122D29 - Lock unit for central locking Implausible signal
static
BC Rear Right Door
System description: TSG HBFS
Software number: 8W0959595M
Software version: 0384
Hardware number: 8W0959595J
Hardware version: 010
Serial number: 0000384830150
ODX name: EV_DCU2RearPasseMAXHCONT
ODX version: 001005
Long coding: 001C80208001020000001100
Trouble codes:
B148754 - Motor for window regulator No basic setting
static
46 minutes ago, rowanw said:
B122B12 - Central locking motors Short circuit to B+ static
There should be a wire issue indeed. If the locking motor has a short circuit to + in your passenger door, it can't operate as expected. This may be the cause of your problem.
Then, the other code may be a result of the previous one :
48 minutes ago, rowanw said:
B122D29 - Lock unit for central locking Implausible signal static
Regarding the Lane assist system :
Check the blinker in your mirror. The lamp may need to be replaced, or there could be some rust causing this short to ground.
Considering the Lane Assist deactivates each time you move the blinker stalk, this may be a reason why it doesn't work...
^^^ This man knows!
Who ? Me ?
Well... Let's wait for @rowanw to make some investigations and confirm (or not) my sayings... Then we'll know if I was right... 😉
I think Bap, like MartiniB and Carlston, are specially designed bots of Skoda to keep us satisfied there is always a solution waiting .... 😁
I think you've forgotten ApertureS. The master bot! 😁
Of course, H.I. is better than A.I. any day.
No, Aperture goes into a category of its own ... he has trascended the "virtuality" and has made those things real 😁
I think if that project car was to make a trip back to CZ more than one engineer would grab his/her head and pull his/her hair ...
There are a couple of short circuit error codes relating to stuff in the door. I’ve known a few cars (not Skodas) with chafed or broken wires at the door hinge where they flex every time the door is opened or closed. This is where I’d start looking.
I ended up replacing the blind spot light with a second hand working one. This cleared up most of the errors. After that the door lock still didn't work and was showing up in the error scan. Managed to get the lock replaced under warranty so all good now
