Fitting a usb charging socket ,where and how please
I’m looking to fit a usb charging socket
Where would I put it and take power feed off from ?
I use what used to be the cigarette lighter. Plug in one. Nice and easy. If you wanted one on dash I would just tie into it as the wiring is fairly easy to get to
Alasdair
Alasdair
Thanks , I’m changing the radio any way for an android one so may look at that when I do it
Not sure of the fuse rating on the socket if you are puting one on dash. May have to put an inline one in.
Alasdair
Well found a video on you tube where a man had added one of those round shaped usb panel sockets and he showed where he put is and took the switched feed from ,
Just got to work out where to put mine as I’ve not got the arm recast centre console
