Particulate Filter Pressure Sensor ‘A’ Circuit
Hi there guys, I’m a new owner of a Skoda Octavia VRs Mk3 (2015) and it’s caused me some very unlucky bother already 🙈
My car just came back from the mechanics today after the engine mount bolts broke on me inside the engine block, leaving the engine hanging to its side. I got that fixed along with the timing belt and water pump replaced as it was time anyway. I had got the car back for 12 hours and the engine light turned on with a loss in power. This is the code that came up when I plugged it into my friends obd scanner (see attached). Is this a simple case of mapping out the dpf or what’s the next best step? Could it be the mechanics fault that just gave me back my car? I did not have this problem before.
Please see below. Suspicious that pressure sensor has failed after remedial work. Suggest that either the sensor has failed or connector to the pressure sensor is not properly connected.
