Canton and PHEV
PHEV owners - Has anyone added the Convenience Plus pack to their car? I'm specifically looking for info re: Canton sound system. Where's the sub?
Had a look at a PHEV today but couldn't see anything in the under floor boot tray ( where the load cover and cables reside ). I wasn't nterested in the particular car I saw today so didn't bother having a good look round, but stupid me didn't think to turn on the infotainment and see if there was actually a sub level in the equalizer setting.
Brochures mention 12 speakers with the Canton system - I'm presuming that means 6 front door, 4 rear door, a centre and a sub, but not sure if this also applies to the PHEV model. Typically Skoda mount the sub in the spare wheel, but with no room for a spare in the PHEV, obviously that's not where it is.
https://www.canton.de/en/partner/automotive/kodiaq/
9 hours ago, shootek said:
That's why I asked the question specifically to those who have the above package.
If you read the article it says subwoofer is mounted in the spare wheel. But given PHEV's do not have a spare wheel nor an area to accommodate one ( the battery prevents a spare wheel ) then obviously that Canton brochure cannot be true for the PHEV.
Even the owners manual only refers to the sub in the spare wheel.
I have the PHEV with canton...
If you check the picture of the speaker position it says that the woofer for the phev is in the trunk.
Here is a picture of mine. The woofer is on the left side.
Big thanks for that. I just looked in the under floor storage, didn't realise you could lift the other floor piece.
I was thinking it may have been something like the box they use in the Enyaq, ( which doesn't have a spare either ), something which I have played around with but thought ineffective compared to the sub in a Kodiaq Mk1.
Unless the cone has sufficient space beside it to move air, that sub looks like it could be even worse than the Enyaq.
Think I'm erring towards a VW Tayron rather than another Kodiaq, but their Harmon Kardon system will be identical to what you've shown above.
Many thanks once again, appreciated. 👍
Edited by kodiaqsportline
