Karoq glovebox/trim removal
Morning, I’ve just picked up a 2019 Karoq and am trying to install a towbar. The bit I’m struggling with is removing the glovebox. I’ve undone every screw possible, dropped the actual box and managed to get the left hand side to drop down but can’t seem to budge the right hand side.
I’ve slid out the multi media and got the cooler moved slightly.
Any help would be gratefully received, can’t find anything on here or generally on t’interweb.
Thanks in advance.
You need three hands, two to push the sprung loaded clips/hinges in and the other to steady the operation - keep at it, you'll win..........not sure you should have to remove any screws?
Open the passenger door, remove side trim, unplug airbag and remove the two or three screws.
Before you reassemble everything make sure all the connectors are still attatched to the audio unit.
I wouldn't recommend anyone unplugging an airbag with the battery attached...🙄
