1.3 MPI Pickup from 2000 - customer lost his only key
Hi all
Cannot find any service info on my suscriptions or the ElsaWin. I need to go to the car owner and take out the immo box and ignition key.
Ignition key, no problems - but where is the box located? So I will know what tools to take with me....
He will then take both to a key maker and get a key made with correct info in the transponder.
I guess I wount have any use of the genuine VCDS I have - or VAGKKL (for Fiat Ecu scan) I have to get the pin number out of the car, for the key maker?
Thank you.
https://www.youtube.com/watch?v=P0gVqlekVSw
That I found before, shows only antenna ring and the transponder inside the key.
Box, I havent seen in the video?
Thank you though =)
The code on the module helps?
In the other end of the ring isn't the modul attached?
Thank you!!
Very much. From the pictures, the box is not farm from the ignition lock.
Interresting page - will save that one. Didnt know Etka was online, for free....
The key has been found. He had left it in his daily rider.....
