A BIG thankyou to this site and forum!
Maybe look into what you can get from your OBDeleven in terms of "fault codes" I would have thought that it was or was able to point you directly to the exact ABS wheel sensor that had failed, doing a quick "clear all stored faults" at first is not the best way to use that scan tool - yes okay clear them all, but record them first as maybe, you are being told what the fault is.
Yes, that is what I did of course. It flagged rear left, so first thing I did was check connection and then clear the codes to see if it repeated (which it did a few yards down the road).
