Need urgent advice – Fog light damage & headlight washer nozzle issue before holiday
Hi all,
What a nightmare I’m having! Not sure if I’m just unlucky, but it feels like every time I go abroad, something goes wrong.
Yesterday, while attempting a tight 3-point turn, I bumped my car into a low railing. The aftermath:
  • Fog light smashed
  • A few dents, bends and scratches on the bodywork
  • Most importantly – the offside headlight washer jet nozzle popped off completely, and all the washer fluid drained out.
I was absolutely gutted when I saw it, especially as we’ve got guests coming from abroad and we’re heading to Europe for a holiday this Saturday (via Dover–Calais ferry).
I managed to pick up the pop-up spray cover – that seems fine – but the barrel/nozzle underneath has either snapped or come loose. I’ve been to a few garages, but they’re all fully booked (classic timing, right?).
A mate suggested getting the original Skoda part (which I’ve now ordered) and said the fix is basically just attaching the new nozzle to the pipe and reconnecting the cover. The catch? The front bumper needs to come off to do the job.
He’s offered to put the car on a ramp and block the pipe to stop any leaks, so I can at least use the windscreen washer for the drive up to Scandinavia. Then after the holiday, I can get the bodywork sorted and have the nozzle properly fitted at the same time.
I’ve tried scouring YouTube for videos on replacing this barrel-type offside headlight washer nozzle, but no luck so far.
My questions:
  • Is this something I could realistically fit myself if I remove the bumper?
  • Has anyone done this before and can share tips or a guide?
  • Any advice for a quick temporary fix for the trip, so the windscreen washer still works?
I can tackle the fog light replacement later myself – it’s this washer nozzle that’s stressing me out right now.
Thanks in advance for any help or tips!
These things happen.
The first thing I would do is get some clear Gorilla tape to seal over the damaged fog light. This will stop any water ingress.
Then, take a look underneath/through the engine bay/through the towing eye hole and make sure that the bumper is securely on - I.E. no major cracks, no majorly damaged fixings. Looking at the damage you should be okay, but it pays to check. Similarly, inspect behind the bumper and make sure nothing is damaged - again, doubt it, but do check.
Regarding the headlight washer, my honest solution would be to plug the end, cover in Gorilla tape and zip tie somewhere out of the way. If you turn the headlights to off, the headlight washers will not activate, at any point.
Hopefully someone can advise on whether fixing the washer nozzle properly is a viable option. If I'm honest, with potential damage to the bumper, I'd be inclined to seal the washer system off, apply tape, and drive the car as normal.
FYI - most dealers can get parts next day. I would be more interested in replacing the fog light on Friday (it can be done with the bumper on), in order to safeguard the electrical system. The washer, IMO, is a nonissue.
I've had an arch liner crack into four pieces the day before a France trip, and the battery die on my Octavia a week before a Scotland trip. It's sods law, but you'll make it.
My plan would be to make sure the car is structurally sound, then electrically sound, and then worry about the washer.
Look at the silver lining - you are very fortunate you didn't crack the headlight! Those things are expensive.
as a quality spare part from Skoda directly, speaking for left-hand drive, 370€ each
Yes, but Austria
Are you saying the entire washer tank has emptied and now isn't holding fluid?
If you only damage the headlight washer, then a little fluid will drain from the pipe but it will not empty the tank or effect the windscreen washer...
1 hour ago, Cairus said:
Yes, but Austria
skoda-parts.com is Cz - they get their stuff straight from the factory down the road, AFAIK. Weird.
That's something confused me as well. But believe me all the fluid id is drained out and giving me warning to top up. Wiper and other side of headlight washer work good. I did try two times with the wipers.. Don't know if it caused to drain out all or not. Nothing i can see got damaged other than fog light and headlight washer jet spray.. Impact was gentle that i was almost not getting out of the car untill someone said that i had damage on the front and part came off.
I can see two reasons for this. 1; no headlamp washer means the reservoir drains by siphoning out the reservoir. Or 2; you have cracked the main reservoir.
1 is obviously better than 2. Plug the headlamp washer tube, refill the washer bottle and report back.
5 hours ago, OccyVRS said:
skoda-parts.com ist Cz – die beziehen ihre Sachen, soweit ich weiß, direkt aus der Fabrik die Straße runter. Seltsam.
read the topic Skoda quality parts
on the topic: removing the bumper and assessing the damage
Huh? You are literally the one that brought up the price of parts -
Edited by OccyVRS
I think we have a problem with the translation...
It might be that the pump that fits into the reservoir has come loose. The rubber seal failed on min and drained tank. I agree with sealing off pipe. You could plug it and kink it using a cable tie and then tie up out of road. Refill tank and see if anything is leaking.
Alasdair
Potentially!
I thought you were making comment on how I was having a discussion on the price/availability of Skoda parts, on a post about removing the bumper and assessing the damage. If not, then I apologise 😂
It's been a long few days struggling to finish my masters thesis, so I'm probably misreading what you said.
Quick update for everyone who replied – I managed to get a garage guy to temporarily sort the washer fluid issue.
He opened up the inner wheel arch liner to access the expansion tank for the washer reservoir, unplugged the hose feeding the headlight washer and clamped it off before refitting. He topped up the tank and now there’s no more leaking – plus the windscreen washers are working perfectly again.
He advised me not to operate the headlight washers until the new nozzle is fitted. But as we know the headlight washers on these cars only work when the dipped beam headlights are on, and then only once every five windscreen washer activations. So for now, I just need to make sure I don’t wash the screen with the headlights on, or I could trigger them accidentally. Does anyone know how to disable headlight washer by the way?
To tidy things up and stop water getting in, I’ve used double-sided tape to stick the headlight washer cover back in place where it popped out, and put clear cello tape over the fog light lens – partly to seal it from water and partly to stop it breaking further until I replace it.
At least the car’s now usable for the trip without losing all the washer fluid – thanks to everyone for the tips so far!
Edited by automass
You can disabled them with an OBD tool (OBD11 on Amazon) but, as I said above, just turn the headlights manually off (as opposed to auto) and they won't activate. I turn mine off whenever I clean my windscreen, as I hate the headlight washers - I just haven't gotten around to disabling them yet.
Personally, unless it is absolutely necessary, I'd try not to use any of the washers. I think you'll survive with a cloth and some spray at services.
I would get some clear Gorilla tape too - you don't want the tape to break down in the sun or rain on the trip.
