Roomster Misfire
On a long drive my Roomster showed the EPC and stability control lights and went into limp mode. It is a Skoda Roomster 1.2 TSI (2014), it hasn't been any trouble over the years apart from an occasional misfire.
The misfire occurs when i depress the accelerator sharpley but has been getting worse until today when the dash lights came on.
My hunch/hope is that a new set of spark plugs will sort out the problem. This is a job i am confident i can do and a smallish investment, would you change the plug coils / leads at the same time?
What do you think?
I think replacing spark plugs might well be all that is required.
When were they replaced, 4 years / 40,000 miles ago or sooner?
Failing plugs can cause premature failure of ignition coils, but do not replace if not required.
See what the plugs look like.
Edited by Ootohere
Hi Ootohere, i am still away from home so don't have the service records to hand. I suspect the plugs haven't been done for at least 4 years, maybe longer. Pulling the lead from one plug showed the top of the plug to be cruddy.
An update to close out this thread.
Changing the spark plugs did the trick, hindsight being a valuable thing i should have done this when the misfire first occurred.. Plugs were pretty poor, I suspect my garage had not changed them for a while. The garage said they had inspected them and they were OK, but i am sceptical.
