AA Wireless
4 hours ago, imart143 said:
Yes, the Huawei P20 Pro supports Wi-Fi 5 GHz, and you can confirm your connection by checking your Wi-Fi network's properties in your phone's settings, usually under Settings > Network & Internet > Wi-Fi. To ensure your P20 Pro connects to the 5 GHz band, make sure that your Wi-Fi network has both 2.4 GHz and 5 GHz bands enabled and that they have different SSIDs (network names).
Hi.. Well I tried again this morning and it's now working perfectly after LOTS of checks!!!
Only thing not working is my YouTube Music... Now it had stopped working before this... Any ideas what I can do.. It's opening but none of my saved music is there, only saying Downloads, which is empty.??
I have Unknown Sources checked on the Developer settings.
12 hours ago, EnterName said:
What device are you talking about?
AA Wireless is the device.
On 26/08/2025 at 20:23, hill79 said:
I use AAwireless with my JVC headunit, there's another thing you can check.
In your phone settings, search for Android Auto, you'll get a menu with a few options to tweak and a 'version' option right at the bottom. Tap 'version' repeatedly and you'll eventually get a notification that you've unlocked developer options.
Tap the three dots to the top right to get a menu popup where you can access developer optionsScreenshot_20250826-201554.png
Finally, at the top of developer options is a tick box to enable wireless connectivity
Just wanted to thank you again for all the help with those screenshots...I am an expert on Developer Options now...!!
On 27/08/2025 at 12:46, imart143 said:
here
Thanks so so much for all your help , much appreciated!!
This thing?
AAWireless | Wireless Android Au...
No image preview
AAWireless | Wireless Android Auto Adapter
AAWireless is the world's first and leading Wireless Android Auto Adapter. ✓ Works out of the box. ✓ Comes with free companion app. ✓ Made in Europe.
Yes thats it, but I have managed to get it working now.. Thx
not sure about ytb music, using spotify works normal..
if you dont have checked unknows sources, app wont even apply on AA display.
try to unrestrict battery usange on YTB music, default is balanced.
Sorted the Youtube Music. I realised that the Wireless connection in the car was cancelling out my data on my phone, so no texts, calls etc weren't coming through, also the Youtube wasn't loading either!
I found a fix and it is all sorted now , finally!!
Thanks again
