Two year old VRsEnyaq - Battery percentage?
Hi all. Bought my VRs a year ago and its just had its second service. I asked the main dealer to do a battery health check and the figure I was given (in writing) was 90%.
The car has done 20K, in my year of ownership I'd say it's been home charged 98% of the time and rarely to 100%. It's usually to 80% however I do tend to charge it up to that amount fairly frequently if that makes a difference?
My question is: 10% battery loss after two years...is that anything I should be concerned with? I know the battery is warranted for 8 years/75% but if there is a problem I would like to get it sorted sooner rather than later. I've asked Skoda UK for their thoughts but it's like pulling teeth to get things done. Any thoughts much appreciated. Thanks
They will have done the quick check. On VWs the form states it can be up to 10% out! If you are really concerned get them to do the "long test" which involves running the battery down the measuring the charge to 100% I believe.
All modern VAG group cars are only charged to a max of 85% by the Alternator so don't really know what that 90% means in VW terms, my VCDS numbers below show the state of mine after 2years 8 months, the (VCDS) charge level is based on "the battery voltage at rest" value which I didn't take in 2021 but the usable battery charge, AH, might be the more meaningful one, mine apparently has gone from 38AH to 33AH in 4 years so hopefully a few more years in this battery, it would be interesting if you could get someone with VCDS to run a scan on yours
14/09/2021 (Battery 59AH EFB, original, from January 2019)
IDE01834 Battery voltage 13.487 V
IDE01836 Battery current 2.639 A
IDE01837 Temperature of battery sensor 32 °C
IDE01838 Battery temperature 27 °C
IDE01839 Battery charge level 85 %
IDE01841 Battery internal resistance 6.6 mOhm
IDE01842 Usable battery charge 38 Ah
12/07/2025
IDE01836 Battery current -4.924 A (engine off, elec load mainly from the DRLs)
IDE01837 Temperature of battery sensor 35 °C
IDE01838 Battery temperature 37 °C
IDE01839 Battery charge level 83 %
IDE01841 Battery internal resistance 8.0 mOhm
IDE01842 Usable battery charge 33 Ah (59AH Battery, original, 6.5 years old)
IDE01843 Battery voltage at rest 12.6 V
12/07/2025
I think the OP is asking about Hybrid EV traction battery - not the 12V starter/hotel battery.
It's an Enyaq, full EV.
Another 1 post newbie?
An Enyaq would not be having a second service at 2 years it would be due it's first.
